big screen Mitsubishi TV
Old 12-12-01, 07:59 AM
Guest
Question big screen Mitsubishi TV
Purchased in 1995. Good working set, but lately when turning on in the morning, picture and sound are ok for 2 minutes ,then picture and sound dissappear and only snow is left. In the next few minutes (1-15) picture and sound return then dissappear again. This has be going on for about 3 months. Today it finally has only snow(no picture,no sound(just noise). Also when we had a picture it would studder vertically(double image vertically), and it would have "tearing"lines from the left bottom side of the picture.
Any help will be appreciated.
Thanks
Old 12-13-01, 03:15 AM
Smokey
Good Morning, rhalama:
A picture with nothing but snow indicates either a channel selector (tuner) or a bad antenna connection. Have you tried another TV on the antenna connection to be sure you have a signal?
A good repair FAQ is located at
http://an.hitchcock.org/repairfaq/REPAIR/F_tvfaq.html
Check Paragraph 26.1 for reference.
The rolling and tearing of the picture may well be part of the tuner problem. The TV signal you receive contains synchronizations signals to stabilize your picture both horizontally and vertically. If the incoming signal is compromised, these signals may have been missing.
Smokey
Old 12-13-01, 10:25 AM
Guest
thanks
Thanks a lot. I beleive it could be the tuner also. If and when I get it fixed, I will update you. Thanks again for the response.
Old 12-14-01, 03:41 AM
Smokey
Thumbs up
Thanks for using DoItYourself.com. And, yes, let us know the results of this repair.
Smokey
