toshiba tv
Old 12-15-01, 05:48 AM
Guest
Question toshiba tv
PLease advise
The toshiba tv i have is having a problem with audio.Sometimes the audio is great but most of times its in and out.The longer the tv runs less chances of audio.Plus it starts to make a crackling noise when the audio is about to go.
Thanks
Roger
Old 12-15-01, 09:21 AM
Smokey
Thumbs up
Good Afternoon (again), rtew1:
I strongly suspect there is a bad solder connection on the audio board in this television. Toshiba is famous for this type of failure.
Do me a favor and give me the model number of the TV and the approximate age of the unit.
Second, the next time it acts up, give it a "whack" on the side of the TV. Does it change the audio problem? Cure it?
Smokey
Old 12-31-01, 04:30 AM
Guest
toshiba model number
Hi Smokey
how are the holiday's going?
Mine iam spending doing my hobby work repairs.
For the toshiba its about 12 yrs old and the model number is cf32c50.I tried wacking it didn't work.
Thanks
Raj
Old 01-02-02, 12:06 AM
Smokey
Thumbs up
Good Morning, rtew1:
Still suspect a bad solder connection that has failed from age. As the set warms up, the circuit boards flex a little from the heat, and the connection loses contact.
You can track it down, of course. Remove the back, turn on the set, and use a long, non-metallic wand of plastic/wood (DO NOT USE A PENCIL) to probe the audio circuit board. When you find a sensitive spot (where the sound comes and goes), unplug the set, and resolder the area. Use a low heat soldering iron and a little 60-40 electronic solder. Resolder all the components in that sensitive area.
Significant to note that you may have to do this two or three times. Most times you can't see the bad connection and just have to keep after it until you finally hit it.
A good website to keep in your Favorites file is at
http://an.hitchcock.org/repairfaq/REPAIR/F_tvfaq.html
Smokey
Old 01-02-02, 03:39 AM
Guest
hi smoke
I will try it out tonight thanks a lot.
Got a response from mike on vcr problem jvc he advised that removing the cage screws up the timing.What do you think?
Raj
Old 01-02-02, 01:58 PM
Smokey
Thumbs up
Big Mike is my hero. Do whatever he says.
Smokey
