Zenith Menu Problem
Old 02-06-02, 02:36 PM
F
Received 2 Upvotes on 1 Post
Cool Zenith Menu Problem
I have a Zenith Advanced System 3 Color TV, model #SE5759Y,it is a 27" Monitor style. My problem is with the onscreen menu options. There should be 3, one for Source, one for Sleep Timer, and one for Time Set. I am missing the one for Source. I need this to be able to access my aux, and s-vhs settings for some of my components. I heard there was a way to adjust the paramenters on the set to fix it, without having to go in and do major work? Any help would be appreciated.
Thanks, Fritoguy15
Old 02-06-02, 04:27 PM
Smokey
Thumbs up
Good Evening, fritoguy15:
I can help you but I need to know which Zenith remote control you are using with your set. To get that information, check your owner's guide. There are so many! For instance:
ZENITH ZEN-100 Universal TV Remote w//Direct Access Keypad
ZENITH ZEN-300 3 Device Universal Remote
ZENITH ZEN-400 4 Device Universal Remote
ZENITH ZEN-355 3 Device Universal Remote w/Direct Access Keypad
ZENITH ZEN-430 4 Device Universal Remote with Audible Big button Keypads (Color-coded keypad)
ZENITH ZEN-435 4 Device Universal Remote with Audible Big Button Keypads (Glow in the Dark Keys)
ZENITH ZEN-450 4 Device Universal Remotes (Color-Coded Keypad)
ZENITH ZEN-425 4 Device Universal Remotes (Glow-in-th-dark Keypad)
ZENITH ZEN-500 5 Device Universal Remote with DSS and Color-Coded Keypad
ZENITH ZEN-575 5 Device Universal Glow in the Dark Remote
ZENITH ZEN-700 7 Device Universal Home Theater Remote with Color-Coded Keypad
ZENITH ZEN-725 7 Device Universal Home Theater Remote with Glowing Keypad
ZENITH ZEN-560 5 Device Universal Remote w/Membrane Keypad
ZENITH ZEN-770 7 Device Universal Learning Remote
ZENITH ZEN-GM2 Universal Remote for Playstation 2
ZENITH ZEN-780 7 Device Universal Learning Remote
ZENITH ZEN-550 5 Device Universal RF/IR Multiroom Home Theater Remote
ZENITH ZSD-100 Infrared Remote Control Signal Sender
Smokey
Old 02-07-02, 11:58 AM
F
Hello Smokey:
My manual says it is a Computer Space Command 3800. It is black and also will control Zenith VCR's. It has a switch at the top to select VCR or TV, also has menu,off-on,andadjust buttons, then a number pad with enter ch. up and down, vol. up and down. Below that are function keys for a VCR. We bought the TV in March of 89'. Hope that is enough information. Also sometimes I use a One For All remote model urc-4060B06.
Fritoguy15
Old 02-08-02, 08:02 AM
Smokey
Thumbs up
Nope! Can't cross that number. Check through these and see if you can find one that looks like it:
http://www.replacementremotes.com/zenith/
Smokey
Old 02-08-02, 11:12 AM
F
Yep I found it there it is 147-13. Will that help you?
Fritoguy15
Old 02-08-02, 04:06 PM
Smokey
Thumbs up
Hello, fritoguy15:
I researched your inquiry and came up dry. I would suggest you contact Zenith customer service and request this information. The actual part number of your remote control is SE2027W. You can contact Zenith on the web at
http://www.zenithservice.com/bin/HPI/HpiHomeMain.exe
Go to the bottom of the web page and click on the Customer Service Link.
Smokey
NOTE TO MMCC: Please start a new thread so that we can maintain continuity with your problem.
Old 02-09-02, 12:23 PM
F
Thanks smokey for trying, I will contact Zenith with the link you provided.
Fritoguy15
