Toshiba TE50T11 50"
Toshiba TE50T11 50"
Hi,
My 2 year old took the ole baseball bat to my projection tv. It cracked the screen since I did not have a screen guard other than that the TV performed fine.
Well we moved to a new home and I decided to fix the cracked screen. I ordered the part for around $100. They said it was an easy fix of a few screws. I opened the screen and found two screens. I replaced the outer broken screen and put the inner lense like screen back on as well. everything looked great until I turned the TV back on. Now a circle of normal viewing screen appears where the clear lense of the second inner screen lies. All four corners are viewable but visibly shaded. I did wipe the inner (lense) screen down with a paper towel and water to remove what looked like dust. It looked a bit smudged when I had finished.
The mechanics of the fix consisted of around 4 screws on each side of the screen and seemed simple. Any suggestions?
thanks,
Tony
thanks,
Tony
Good Afternoon, tony89:
Two things here:
1) When you clean the screen, you need a special cleaner and a very soft cloth. The paper towel was not a good idea. Check this website for a VERY good cleaning agent:
http://www.tritronicsinc.com/proclean.html
2) Did you know these screens are polarized? Sounds like you have one of the screens 90 or 180 degrees out of whack.
Smokey
Two things here:
Smokey
All my part sources list the screens as no longer available.Try putting the model number plus "parts" in a search engine and search everywhere.You might get lucky with a few hours of searching.
