Mitubishi Model VS410R TV
We have a rear projection Mitsubishi TV on which the R+H line will not realign with the other lines. Part of the line does align with the rest of the lines, but the rest of it will not. How do we correct this?
Good Afternoon, BLSell:
Not an uncommon problem with that series of sets. This FAQ seems to apply to your problem:
Original Question:
Red convergence jumps way out of whack, horizontally, after the set has been on for a few minutes. Then, it wiggles back and forth. After 15 minutes or so, it locks back in and stays good for hours. It is not dirty contacts in the user's convergence pots. This set has a horizontal speaker grill, below the screen. The chassis is just behind this grill. This grill is removable, allowing easy, front side access to the chassis.
Archieved Answer:
The problem is most likely the STKxxxx convergence output ic's. There are two, one for red and one for blue. Change them both, the blue one will also be going soon. They are not expensive.
Smokey
Original Question:
Archieved Answer:
Smokey
