toshiba 50''
Old 03-14-02, 01:36 PM
robmoni
toshiba 50''
First I wanted to thank you for your advise before on my personal T.V. We now have a problem at work that is also beond me. It is a toshiba, I believe 50'', model#TP48950. The problem is the convergenge is obviously way off, but the small control knobs on the front of the set fail to make any kind of adjustment.
Any guidance on repair or cost is appreciated.
Old 03-14-02, 01:42 PM
Smokey
Thumbs up
Good afternoon, robmoni:
This is a common problem with Toshiba.
Remove the convergence board and check for bad solder connections. Correct them with a little 60-40 electronic solder and a low heat soldering iron.
If that doesn't solve the problem, replaced the two IC's on the convergence board. They have a history of giving up their lives after a couple of seasons.
Smokey
