Magnavox screen creep
Old 03-16-02, 02:29 AM
maibrick
I have a Magnavox 19inch with build in VCR. Model number CCT190ATO2. Its build date was Dec.1995. Its picture has started to go black at the bottom and slowly creep up. If you turn the tv off it returns to normal. Is there anyway to fix this problem.
Thanks for any help you can provide.
Old 03-16-02, 08:17 AM
Smokey
Thumbs up
I would suspect a bad filter capacitor (or one that is going bad)
in either the low voltage supply or around the Vertical Driver.
If you want to open the set and track it down, you can get a service manual at http://www.treasurechestcorp.com/Default.htm
Smokey
