1/4'' horizontal picture
Old 03-16-02, 06:51 AM
Smokebug
I have an Emerson 19" that sometimes when you turn it on I only get a picture about 1/4" tall all the way across the screen If I turn it off and then back on it is ok. Sometimes a very light tap to the side of the box it comes on. The sound is fine. Chuck
Old 03-16-02, 08:13 AM
Smokey
Thumbs up
Bad solder connections prevail in the Emerson units.
Open the back of the set, poke and prod around with a non-metallic wand (NOT A PENCIL) of plastic or wood, and find the sensitive spot where you make the picture come and go.
With the set off, of course, use a little 60-40 electronic solder and a low heat soldering iron (NOT A SOLDERING GUN) and do a little wholesale resoldering of connections on the circuit board.
This will usually cure your problem.
Smokey
