Toshiba TV Problem
Old 03-17-02, 12:07 AM
KKL
Unhappy Toshiba TV Problem
Toshiba TV48D90
Convergence problem on Red color. Only affecting around one-quarter of the left display. The Red color on LHS shifted to the center by about 3 inches on color test.
Would this be due to convergence ICs problems? If so, how can I locate the convergence board inside the box?
Many Thanks
Old 03-17-02, 08:26 AM
Smokey
Pretty good bet that the convergence IC's are the problem. Another possibility is bad solder connections on the convergence control board.
Location: Suggest you pick up a service manual on the set at a very reasonable price. This will give you locations of the items and part numbers that you need. Find yours at
http://www.treasurechestcorp.com/Toshiba.sm.TV.html
Good site! Secure ordering, etc. Heard a lot of good things about them.
Smokey
