Price for repair Job VS-5055 and is it worth getting fix?
Old 03-20-02, 09:24 AM
imatoolman
I have this Mits VS-5055 projection TV and was wondering if it is a high voltage problem what I should expect to pay a repairman for fixing it.
I have a guy coming for a service call for $50 and then what ever it cost to fix the problem.
Just wanted to make sure there isn't a reset switch some where that could reset the high voltage to the tubes.
Any info would be great or a web site that could help me out.
Thanks again
Tony
Old 03-20-02, 09:27 AM
imatoolman
Also
More info
When this problem happened my wife was watching it and she said she heard a switch noise as if you turned the set on or off and the screen than went black but still had sound signal working
Thanks again
Old 03-20-02, 01:07 PM
Smokey
Thumbs up
It could have been a surge. Chances are that the HOT
(Horizontal Output Transistor) shorted and the overload circuit has kicked in.
You've made the right move by calling the tech.
Smokey
Old 03-20-02, 03:50 PM
imatoolman
HOT Shorted
Smokey
If this is the problem what should I expect the Service guy to be a fair charge for this repair?
Any ballpark figures
Thanks again
Tony
Old 03-20-02, 04:14 PM
Smokey
No ball park figures from me. It varies from site to site. You are in New Yawk so expect to be drawn and quartered in the process.
Your bill is going to be in the high three figure catagory.
Smokey
