Zenith TV (fuse)
Old 03-20-02, 10:51 AM
violet a duncan
Question Zenith TV (fuse)
I have replaced the fuse in the tv three times and everytime i plug it in after replacing it instantly blows the fuse, before i can even turn it on... Any suggestions or if you have a clue as to what is wrong advice would be helpful.
Old 03-20-02, 01:21 PM
Smokey
Thumbs up
Not knowing a model number or age of the set, I can only speculate on this issue.
There's a good chance that a diode or filter capacitor has shorted in the low voltage supply. Another option might be the Horizontal Output Transistor (HOT) has a way of shorting out and snuffing the fuse.
A good website to have in your favorites file is this one:
http://an.hitchcock.org/repairfaq/REPAIR/F_tvfaq.html
Read section 22.6 for more detail.
Smokey
