RCA 52'' tv blue hallow and shut off on it own
Old 03-26-02, 11:02 AM
BUCKLINDA
Question RCA 52'' tv blue hallow and shut off on it own
My tv is only 2 years old and i bought it at Wards.The problem I am having started about 3 weeks ago with a little light yellow spot in the bottom left corner, that went away ,but now everything has a blue hallow. yesterday the tv just started shutting off on its own. When I turn the tv on it ,it is on channel 54. hope you can help,thank you for your time. Buck
Old 03-26-02, 11:51 AM
Smokey
Thumbs up
This RCA set has a history of High Voltage Deflection blocks breaking down and I have a feeling this is happening to yours.
As such, the set will shut down to protect you from X-Rays. As for the Channel 54 thing, that is a mystery. It may be a default on start up after being shut down with X-Ray overload protection.
Need a service manual on the set? Try here:
http://www.treasurechestcorp.com/Default.htm
Need parts? Try here: http://www.unionel.com/
Smokey
