Mitsubishi VS 5055 High Voltage board
Old 04-01-02, 09:58 AM
imatoolman
I think I have this narrowed down to the power board, there is a shorted diode and resistor on the power board on the side of the flyback the diode location is D505 and the resistor is R555 and R510 how can I find out the original values of these parts they are burnt and can't read codes to well.
Also what would cause them to burn out I know to much voltage but what is causing the voltage being to high something before them is letting to much Voltage through.
Thanks anything would help me on this one.
Old 04-01-02, 03:53 PM
Smokey
Thumbs up
Good Afternoon, imatoolman:
The most righteous thing to do is pick up a service manual on the set so you aren't flying blind on this repair. Here is a site that delivers fast, has secure ordering, etc. Give them a try. We're had great response about them:
http://www.treasurechestcorp.com/Default.htm.
And, the most common problem that causes those burned parts is a shorted deflection yoke.
Let me know if you need parts. I have some places you can check.
Smokey
