Rca Projection TV Model ppr475t
Old 04-10-02, 07:29 PM
jtv4120
I have a RCA Projection TV Model # PPR475t. The set after it warms up cuts out, but power is still at on/off switch. What could possibly causing this failure. I had it repaired once lasted about 2 weeks.
Old 04-10-02, 08:19 PM
Smokey
Thumbs up
Good evening, jtv4120:
That's an old set you have. Anything that is 9-10 years old is labor intensive. You fix one problem and thre others appear.
Best advice I can give you is to take the family shopping for a newer unit. Next time, think Mitsubishi.
If you want to get into this beast, yourself, then you need a service manual to guide you. I recommend you check this site with secure ordering and rapid reply:
http://www.treasurechestcorp.com/Default.htm
If you are independently wealthy and have nothing to do with your time and money except tackle lost causes, this is a good place to start.
Smokey
