Cloudy and Foggy in Places
Hi there. I hope someone can help me. I received a Sony KPR-4150 from a friend. Half of the picture is really clear but the bottom half and especially the bottom corners are really cloudy/foggy. I have tried to clean the inside and the screen but it's to the point that if there are words in the bottom corners, you can't read them. Thanks in advance for your help!
Good evening, krb:
Clean the entire projection path from the tubes, through the mirrors, and finally the screen. Use this stuff:
http://www.tritronicsinc.com/proclean.html
Second probability is that the cooling fluid between the lens and the projection face of the CRT's has gotten cloudy and low. The fluid gets contaminated by bacteria now and then. This means draining all the fluid, cleaning the junk out of the lenses, and refilling the reservoirs. For that, you need a replacement fluid. Here is an example:
http://www.mgchemicals.com/products/803.html
Smokey
Smokey
Get a Service Manual on the set here:
http://www.treasurechestcorp.com/Default.htm
They have fast delivery, secure ordering, etc. Tell them Smokey sent you from DoItYourself.com.
Smokey
Smokey
