No Sound - No Picture Mitsubishi
My technician while trouble shooting the repair of a Mitsubishi, Projcection TV, Model VS-6002R, and having replaced the flyback found that the system had no sound from speakers or vertical. A single horizonal line appeared accross the screen. Any suggestions as to what may be the problem and or a solution to restore the TV to good working order. Before the system (TV) went off, loss of power, the picture was good with sound. Also, could hear a clicking sound when attempting to turn the TV back on without results. Appears that the installation of the flyback solved the power on and off problem, but no sound, no picture.
Thanks,
Bailey
Thanks,
Bailey
You're still in an overload status. Tell your tech to check for a shorted yoke on this unit. I suspect that a yoke on the neck of a projection tube has shorted and is shutting down the vertical drive.
Need a service manual on the set? Check here:
http://www.treasurechestcorp.com/Default.htm
Having trouble getting parts: You might try this site:
http://www.toshiba.com/tacp/customer_solutions.html
Smokey
Smokey
