kv27s20 tv
Old 05-20-02, 08:50 PM
dano99487
kv27s20 tv
smokey,where might this HOT be located.would it be the board that is on back of picture tube,or power supply board?thanks dan
Old 05-21-02, 05:26 AM
Smokey
Thumbs up
Good Morning
Got to this website at Sams Photofacts:
http://www.samswebsite.com/photofact/pf_search.asp
Plug in your model number and you will find their Photofacts 3735
will provide you with schematics, parts locations, part numbers, set up procedures, etc. Excellent information.
Next, to order parts, I recommend you talk to Sony. You can find all the information on them at http://www.fargo-ent.com/p_s_dir/s.htm
Check under SONY NATIONAL PARTS CENTER for your needs.
If you need further information, respond to this thread and we will do our best to give you the information you need.
The HOT, incidentally, is normally to the right of the picture tube when you are looking into the back of the set. The Photofacts will give you the exact location.
Smokey
