Remodeling this outdated upside down exterior
Old 12-10-21, 09:00 AM
D
Hello all,
We are interested in remodeling the exterior of this property to make it less of an eye sore. Its a great location, but clearly needs remodeling. Does anyone know a site or have more of a vision for what can be done with this upside down looking home? Thanks in advance.
Old 12-10-21, 09:07 AM
P
Received 1,952 Upvotes on 1,748 Posts
What is your budget? Are you planning a big project or just a coat of paint?
Old 12-10-21, 09:31 AM
D
I feel like a coat of paint would be lip[stick on this pig
we could do probably up to 100k with a HELOC and assuming the remodel would add the value back to the home
Old 12-10-21, 11:22 AM
Received 786 Upvotes on 689 Posts
IMO changing the 2nd floor roof line would help a lot, have no idea what that would cost.
Old 12-10-21, 12:11 PM
Received 281 Upvotes on 252 Posts
The main problem in my opinion is that it looks like a second floor has been plunked onto an existing floor
I think just changing the color of the first floor to white would improve it.
If the white looks good then perhaps change the window trim etc. color.
Then if you liked it perhaps horizontal white siding the same as above would make it look a little better.
Old 12-10-21, 12:25 PM
D
paint would definitely be a safe cheap option to start with. thanks
Old 12-10-21, 01:30 PM
Painting the siding on both floors the same color would make the top floor not stick out so much.
Old 12-10-21, 01:32 PM
Marq1's Avatar
Received 1,209 Upvotes on 1,098 Posts
That is going to be a tough one.
Eliminating the aluminum siding and awnings for sure. This is something that an architect would be able to help with because it's not a simple change the color situation.
BTW, I have a BIL who does this for older homes in upscale neighborhoods, he does amazing modifications but budget is always a factor!
Old 12-10-21, 01:51 PM
H
Received 279 Upvotes on 239 Posts
Well, the first place I'd start would be browsing through the old "Sears Catalog Homes" images to get ideas.
Because the Sears homes are so common on the East Coast & Mid west, you can "blend in" much easier.
https://www.vintag.es/2019/02/sears-catalog-homes.html
Next thing I'd do is check whether the beams and joists meet engineering requirements - that's a HUGE flat roof, I'd worry about snow loads if you are in north Jersey.
Aesthetically, you need a side porch under the right-side overhang to provide a "base" so it doesn't look top heavy, which could help create a 2-story porch look.
For a full renovation, I see 2 logical options
First, a pseudo mansard / 2 story porch look
Second, a "pseudo-converted-barn" where you would add stone balustrades under the edges of the overhang to make it look like a cantilevered bank-barn, then extend the triangular roof line out where the porch is now. That might be easier as an actual addition, budget-dependent.
