Duroc wall bulges at the bottom due to shower pan liner
Old 10-17-22, 06:36 AM
R
Hello everyone,
This is for a stall shower in a rental property. Duroc was placed over the triple folds of the pan liner at the corners and it causing a bulge of about 1/4 at the last 6 to 8 inches of the bottom of the walls. I have already put the first coat of Redgard waterproofing and I like to know if the bulge will be detrimental for tiles. My plan was to install 12 x 24 porcelain and one inch mosaic tiles on the pan floor. Due to the bulge I was thinking of installing the 1 inch mosaic tiles up to where the bulge ends. I am debating as to whether demo the wall and start over by furring the studs or just live with it. What do you guys think?
Old 10-17-22, 07:55 AM
XSleeper's Avatar
Received 1,838 Upvotes on 1,654 Posts
If you want everything perfectly plumb like you would need it for wall tile, you would shim the studs.
Old 10-17-22, 07:56 AM
XSleeper's Avatar
In a rental... no I don't think it's worth the trouble.
