Closet / Ensuite Floorplan thoughts
Old 05-02-23, 02:05 PM
C
Would appreciate any opinions on our initial floorplan thoughts for adding a walk in closet and ensuite to our master bedroom.... The fireplace is already there - so we are working around that....
Old 05-02-23, 03:50 PM
P
Received 1,952 Upvotes on 1,748 Posts
How much leeway do we have? You said the fireplace is existing. What about the walls? Do you have to work within the walls shown on your drawing or can they be moved?
C-COOP voted this post useful.
Old 05-02-23, 04:30 PM
C
All the walls within the bedroom/closet/ensuite either don't exist or can move.....
Old 05-02-23, 05:31 PM
C
Received 134 Upvotes on 110 Posts
What's across from the toilet? A stacked washer/dryer? Most adults never (or very rarely) use a tub, just the shower, so you might consider ditching that in favor of a larger vanity space and more storage. We're in the process of redoing our master suite and have a tub in the guest bath but not in the master.
Since you have another bath in the lower left, would it be better to swap the bed and bath so your plumbing is closer to the other bath? In any case, give some thought to how the plumbing (especially the drains) will run and tie in to existing as it can be a challenge in a remodel. Another plumbing consideration, since you are in CA, is to try to avoid plumbing in exterior walls to minimize any chance of frozen pipes. It can be managed with proper air sealing and insulation practice, but it's easier if you can avoid it altogether.
Are you of an age (or health) where you should consider accessibility? Wider doors and low thresholds are your friend in that case. And while having the WC in a separate cubby is nice, it's not practical for someone using a chair.
Old 05-02-23, 06:51 PM
C
Yes - that is stacked washer / dryer. There is currently plumbing near the new area - there is currently a wet bar there.
Lots of good input - would rather have the plumbing closer to existing stack, but think I can make this design work.
The bath is not my decision ha ha - and would have to be non-optional…
Am considering making closet another foot shorter to add the footage to ensuite as well…
Old 05-03-23, 04:36 AM
P
"...would rather have the plumbing closer to existing stack..."
Where is the existing drain stack located?
Old 05-03-23, 12:03 PM
C
behind existing toilet, but don’t want to move bedroom - prefer it o. the backyard
Old 05-10-23, 02:01 PM
C
Thanks for all the input, made some changes... any thoughts on updated design?
or this:
