humidifiers
Old 02-07-04, 04:05 PM
JIM GOULD
humidifiers
WHAT IS BETTER A BY-PASS OR POWER HUMIDIFIER, APRILAIR OR HONEYWELL??????
Old 02-07-04, 04:13 PM
Jay11J's Avatar
The by-pass would be better since it has less parts, and no moving arts. = to quiet.
The power one is still good. but is has more parts, and a fan to blow the air over the pad.
Only time I would suggest a power one is you don't have a space to put both the unit itself along with the 6" pipe tying into the other duct..
As for Brad wise, they are both good. April Air been around for a long time. We have Honeywell at Home Depot, and heard good luck with those. I've personaly been around the April Air when Iw as in the field.
Old 02-07-04, 06:24 PM
Ed Imeduc's Avatar
Ill go with jay here If you can for sure go with the bypass some call them a flow through type humidifier. But the power ones. I would not go for the indoor and out door controls. You can go say with a sail switch and a humidistat . A current sensing relay and a humidistat or a relay on the blower and the humidistat. This way when the blower is on the humidistat can turn the humidifier on or off .
If it can be dont we tap the water line to it in the hot water line. ED
