Trouble wiring Honeywell 360 humidifier
My hookup for the Honeywell 360 power humidifier worked ok for about five minutes, then the solenoid got very hot and everthing died. Help.
I wired it per figure 5 here--
http://electronicaircleaners.com/dat...stallation.pdf
The 24vac transformer taps in parallel to the furnace blower motor wires. On the low voltage side, one wire goes to the solenoid, one goes to the humidistat. The transformer low voltage output does cycle on and off with the furnace. What am I doing wrong? Thanks in advance.
Other instructions
The instructions here look a bit different , am I missing something?
http://electronicaircleaners.com/dat...oduct_data.pdf
I do have the 8908 model humidistat.
could I?
I checked. I'll check again. The only wires that connect to the solenoid and the humidistat are the low voltage 24v off the transformer. Could my humidistat be bad letting the 24v flow nonstop? The transformer voltage looks correct and does cycle off/on with the furnace motor according to my voltmeter.
the 24v transformer low voltage wires -one goes to the humidistat, one goes to the yellow wire on the solenoid unit. the other wire on the humidstat hooks to the second yellow wire by the solenoid. I did confirm 24vac output from the tranformer with a voltmeter.
The funny thing is the humidifier kept going even when the furnace cycled off.
The transformer is spliced in parallel to one black and one white wire that goes from the circuit board to the blower motor. With an ac detecter, the black wire seems to carry constant current when the furnace is cycled on , but the white wire is mostly not detectible.
Should I hook the transformer high v side to the circuit board connectors that are marked HUM115v and EAC instead? there is also a HUM24v connector on the circuitboard but how would the 24v ground lead be labeled?
