old humidifier
old humidifier
I notice a small leak coming from my humidifier, i opened it up and its full of mold and mineral deposits. I just moved into the house about 1 year ago an have not services the furnace. it looks like the humid does not work, but it is still hooked up to the water supply via a peircing clamp coming from the hot water line from my h2o heater. is there any way i can shut this valve off, or do i need to remove the peicing valve and patch the pipe to stop the water flow.
thanks
jc
thanks
jc
Received 1 Upvote
1 Post
That small valve there on the water line should just close down like any other water valve. Then you can work on the humidifier .Or Id get a new one and put it in for sure. you do need them in the winter.
ED
ED
