Fan powered humidifier and air leak - help
Old 06-30-05, 10:49 AM
K
Question Fan powered humidifier and air leak - help
We have just installed a new Carrier system (A/C, furnace, and humidifier). The fan powered humidifier is installed on the A-coil housing. When the A/C is running (or setting the fan to ON position), air is leaking from the humidifier. Is there a way to seal humidifier in summer or at least reduce the air leak?
The humidifier is a Carrier LFP. And I was told that it is the same as an Aprilaire 700, just different color.
Thanks.
Old 07-03-05, 05:38 PM
Jay11J's Avatar
Where is the air leaking from?? I'd call the installing dealer back to seal the leaks.
