Honeywell HE265 Leaks
Old 12-04-05, 12:22 PM
riker818
Question Honeywell HE265 Leaks
Ever since I replaced the pad in this humidifier a few weeks ago, the unit has been leaking. I've checked all the drain holes, there are no kinks in the tubing. I've noticed that alot of water is flowing through the tubing and down into the pad all the time, though, even when the furnace is not running. Is this a problem? Should the water stop when the furnace does and could this be causing my leak?
Thanks.
Old 12-04-05, 07:06 PM
Jay11J's Avatar
yes, the water flow should stop when the furnace stops. (blower).
Does it stop if you undo the wire to the solenold valve?
