HE 265 A Wiring question
After installing the unit to a new Goodman furnace 93,000 btu /with air cond. I really need help with the wiring . I'm pretty sure the furnace will have the hum connection somewhere on the board. and I am wanting to hook to the hot water and have the humidifier work when ,both the furnace heats and when just the blower is going. (If any problems with this so far,let me know). I have the humidastat mounted on the wall next to the furnace Please tell me exactly how to wire the furnace,humidastat and if I'll need the transformer.
You will need the transfomer.. I do NOT suggest "stealing" off the control board for 24 volts.
Check the install manual to see if the HUM is 24 or 120 volts. If it's 120 volts, then yes use the transfomer..
HUM will be heat only fan that turns on the humidifer.
EAC will be be fan any time to turn on the humidifer.
Next to the furnace?? It should be on the return duct or in the living area.
