For a by-pass humidifier
Old 11-10-06, 11:22 AM
R
Can I install the humidifier unit on the supply plenum and run the 6" duct from the return plenum to the humidifier? My space is so limited that I can't fit the humidifier unit on the return plenum.
If it is installed this way, are there drawbacks to do it like this? Are the results the same?
Old 11-10-06, 12:04 PM
Ed Imeduc's Avatar
Wink
I dont know what one you have . But the Aprilaire bypass one show it on the Plenum and the bypass pipe going into the return air drop.
ED
Old 11-10-06, 12:19 PM
R
I have the Desert Spring one at home right now, but I may return it for an Aprilaire if that will work. My spaces are so confining in and around the furnace, it is probably the only way installing a humidifier will work.
Thanks for the info. It really helps.
HTML code is On
