No water to humidifier
Received 0 Votes
I had a new Bryant 90i furnace installed this summer and had the old Aprilaire 550 installed on it. Everything is controlled from the Evolution thermo. Problem is I'm getting no water to the humidifier. I checked the power going to the solenoid, that's fine. So I replaced the solenoid thinking it was the problem. Still no water to the humidifier with the new solenoid. When the control says the humidifier is on there is 24vac going to the solenoid. So what's going on here?
When they put it in the new furnace they turned the water off to it. Ill bet they didnt turn the water back on. Have you checked that. Do you have water to the solenoid in --side
