Replacing a Skuttle 80 with an Aprilaire 600
Will this require any special parts? Any suggestions or advice would be GREATLY appreciated.
A flow through humidifier uses quite a bit of water. Wouldn't it be expensive (and wasteful) to use hot water? I'm not meaning to be contentious, but am truly curious.
It may cost a bit more with using the hot water. but it will incresse the effcency a bit more (steam has water vaper) and also the water has less "stuff" in it since the water sits in the water heater, and it falls out of the water.
I hoooked mine up last fall, and I didn't see much incresse in gas by doing this.
