Coolerator Dehumidifier Help
I have an older(?) Coolerator Dehumidifier model 227 F . Works great, but I need a new fan motor. Having trouble locating a motor. Had 1 quote--$100!! forget that..
Info & numbers on motor:
Leece-Neville
Model H00143404G
RPM 1350
Amps .95
Type 404G
The shaft(from motor face to end of shaft) measures 5/16" by 1"
Motor is 2 7/8" long
2 bolts (center of hole to center of hole measurement) 2 13/16"
Motor width is 3 1/4"
(all measurements are approximate)
Any help/info where I can get a motor at would be greatly appreciated!
Thank You!!
Leece-Neville
Model H00143404G
RPM 1350
Amps .95
Type 404G
Thank You!!
