Wiring to use furnace contoller HUM terminal?
Old 10-14-07, 06:32 PM
C
The various posts about humidifier installation have been very helpful. I’m currently installing a Honeywell HE220 By-Pass Flow-Through unit on my York unit. Could one of you who have “been there, done that” confirm my wiring configuration.
I have a White-Rodger 50A55-843 “Universal Integrated Furnace Control” which has optional spade terminals for a HUM humidifier. So, I should be able to simplify from the standard instructions. Instead of: (1) transformer -> (2) humidistat -> (3) sail switch -> (4) humidifier solenoid value), I should be able to simply do: (1) Furnace Control HUM -> (2) humidistat -> (3) humidifier solenoid value (i.e., HUM provides the 24 Volts AC and since it’s only active when the furnace is on, I don’t need the sail switch either). Is this right?
I’m also curious if anyone has any experience with the Honeywell H1008A1008 Automatic Humidity Control with HumidiCalc+. My kit came with the H8908B Humidistat which should be fine (but I’ll need to adjust it as the outside temperature fluctuates). I’ve seen the automatic unit for about $75. Does it work as well as it sounds? Do I need the outside temperature sensor?
Thanks
Old 10-14-07, 07:14 PM
Jay11J's Avatar
Yes, that is right. Easy does it!
Thanks
I've never used that control, I was planning on getting that one when I was looking at humidifier, but I upgraded to the Honeywell IAQ t-stat that controls my humidifier.
The out door sensor is great if you live in area that has extream temp changes (like Minnesota), otherwise, if you are down south like Missouri, then the outdoor sensor is not really needed.. Just dial down if the temp is going to get really cold.
