Aprilaire 600 only working in test mode
Old 12-05-07, 09:29 AM
Hi all, just installed a couple of Aprilaire 600's the other day and I'm having the same problems with both.
The systems are installed in automatic mode and operate in "test mode" but will not operate out of "test mode".
Outside temperature is 35-40 degrees and the resistance of the temp. sensors at the humidistadts measures ~27 k Ohm. The humidifier is installed in the supply plenum and the humidistadt is located about 5 feet (farther form furnace) away from the humidifier.
On a side note, I used the manual mode resistor with similar results (works in "test mode" but not out of it.
I haven't used a true hygrometer, but my cracked and bleeding lips in the morning tell me it's pretty arid in the house.
Thanks for any and all help.
Old 12-05-07, 05:12 PM
Jay11J's Avatar
Where is this humidistat mounted? supply or return?
What wires are hooked up to where on the humidistat?
R, C, W/G, Cf. H.
Old 02-05-11, 03:42 PM
I'm having the same problem as the OP. I'm attaching the pictures of the wiring. Can you please let me know if this is ok? Please let me know if you need more information.
BTW The test mode works only when I set the switch to bypass, and if I move it toward power it s does not work in test mode also.
http://dl.dropbox.com/u/457448/humidifier/Photo.jpg
Thanks in advance.
BK
R, C, W/G, Cf. H.
Old 02-05-11, 03:55 PM
hvactechfw's Avatar
Received 2 Votes on 2 Posts
cant tell from your picture what the other end of the wires are attached to, you'll have to trace them back and then post findings here
Old 02-05-11, 04:41 PM
RC is connected to this image below
http://dl.dropbox.com/u/457448/humidifier/RC.JPG
H is connected to and 2 wires are also connected to the solenoid valve.
http://dl.dropbox.com/u/457448/humidifier/H.JPG
OD is connected to the sensors outside.
Does this look alright?
Thanks for helping out!
Old 02-05-11, 04:49 PM
hvactechfw's Avatar
DO YOU HAVE A GAS FURNACE? Or HP system?
Old 02-05-11, 05:01 PM
It is a gas furnace.
Thanks
BK
Old 02-05-11, 05:34 PM
hvactechfw's Avatar
Old 02-05-11, 06:21 PM
Very helpful diagram. I will double check the wiring. Now if I want to test if it works in manual mode do I need the resistor? or is there a way to put in manual mode without the resistor?
Thanks again.
Old 02-05-11, 09:25 PM
hvactechfw's Avatar
need the resistor for manual mode
Old 02-06-11, 06:31 AM
is there an alternate part that I could buy at a Radio shack or any local store. I will eventually buy the right part @ Aprilaire eStore.
Thanks
Old 02-06-11, 08:12 AM
hvactechfw's Avatar
which control do you have? I was thinking you had the 60 control. if you have the older style #56 or #58 then you can may be able to find a store that carries a 46K resistor. you may have to solder wire onto ends of resistor, but doubtful
Old 02-06-11, 11:45 AM
I have #56, I looked around for a 46K resistor but only found a 47K from radioshack. Can I try using that or does it have to be exact 46K?
Thanks
Old 02-06-11, 01:32 PM
hvactechfw's Avatar
you should be able to use that.
Old 02-06-11, 03:20 PM
hvactechfw,
Thank You very much for your help. It now works in the manual mode using the 47K resistor from radio shack. I must have a bad sensor or something. works fine in manual mode now.
Thanks again!!!
Old 02-06-11, 08:41 PM
hvactechfw's Avatar
no problem, glad to help......
