Aprilaire 560 wiring
Received 0 Votes
I need some help please. I have an Aprilaire 560 and a Bryant furnace. I recently moved in and the furnace needed some work. The Aprilaire has two wires going to the terminal block on the furnace, a red and a white one. Does anyone know to which terminals I connect these?
You should have a 24volts HUM on the board for one wire, that should be going to a humidistat, and other wire from humidifer should go to 24v C/COM.
Really don't matter what color wire is what. It's low voltage. but most do Red to HUM, and White to Com.
