Aprilaire 600 relay source voltage range
I'm in the process of installing an Aprilaire 600A on my furnace: Trane XE 80 Model TUD080C936B0 mfg 9/94 with the White-rodgers controller model 50A50-405, which doesn't have the EAC/HUM terms.
The Main question I have is the Low voltage transformer in the furnace has an output of 28vac. Will this cause the Humidistat to short out if I use it as the voltage source?
My second Question, I had to set up humidifier's plenum connection for the right side. It seems the grey water tube from the solenoid is too long. Can I cut it to fit?
Thanks
Thanks
Thanks
Thanks
