Install next to central air evaporator (A coil)?
Old 01-30-08, 03:12 PM
T
Question Install next to central air evaporator (A coil)?
I just got a Aprilaire 600A and have been debating where to mount it. I've read the forums, but didn't see this specifically address. I have low ceilings in the basement. If I mount the humidifier on the supply, I'd have to cut into the plenum right next to the central air's evaporator (A coil). Would mounting the humidifier cause any problems?
I figure since the evaporator natural get wet during the summer and since the humidifier is added moisture through evaporation, this wouldn't be a problem.
The alternative is to install on the return where there is much more room. In either case, I plan on using the hot water supply. I'm in Wisconsin and the cold water gets very cold in the winter.
Thanks in advance for any replies.
Old 01-30-08, 03:19 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
Id check first and see that it wont face right into the flatside of the A coil there. The humidity wont hurt the A coil.
Old 01-30-08, 03:41 PM
T
By flatside, do you mean the side that has the copper tubes exposed or the side by the fins? I would be installing it on a side that faces the fins (next to the A so to speak).
Old 01-30-08, 08:17 PM
Jay11J's Avatar
Right, want on on the side of the A. not in front of it to block the air flow.
