How to connect aprilarire 600m with carries 58GFA
Old 02-01-08, 07:00 PM
O
I can't find Hum connection with the control board.
The connectors on the board
W Y R(24 VAC Thermostat Terminals) C (24 VAC Common)
EAC-1, EAC-2 (Electronic Air-Cleaner Terminals)
Sec-1 (24-VAC Power) Sec-2 (24-Vac Common)
The humdistat has I+ I R C H ODT .
If I only want the humidifier to run when the heats on you would connect it to the HUM terminals, but I didn’t see there has the Hum connector. Anyone knows how to do it. I’m very appreciating how to wire connection.
Old 02-02-08, 06:06 PM
Jay11J's Avatar
This model won't have it..
This is what can be used, wire the transformer on this, this will power up when the fan comes on.
