Help with HE360 wiring
Old 01-23-09, 07:54 PM
I am hooking up the HE360. So far I hooked up a circuit sensing relay to the nuetral wire on the blower motor, and I am wired to the humidifier and the manual humidistat, but nothing works yet.How do I power it up from there? I do have HUM H and HUM N on my Lennox Furnace. The HUM H is 120VAC while the blower is running. Any advice would be greatly appreciated.
Thanks
Old 01-23-09, 08:00 PM
he360 wiring help
Upon further research. Can I just come off of the HUM H and HUM N with a step down transformer and just wire up the humidifier and the humidistat and do without the current sensing relay?
Old 01-23-09, 09:33 PM
Jay11J's Avatar
that's correct, you can do the transformer, and forget the A50 relay.
Old 01-27-09, 07:35 AM
HE 360 Help
It appears I have a bad transformer. I hooked the black from hum h the white from hum n and the green to a ground. When I first fired it up I had 24 v coming out of the transformer, But the humidifier would just continually run even when the furnace was down. After an hour it stopped working . I then checked the voltage coming out of the transformer and I had nothing. Does this sound like a bad transformer? Is there anything that could be wired wrong that would cause a brand new transformer to go bad so soon?
Old 01-27-09, 07:42 AM
HE 360 help
Here is how I am wired so far. Black wire from HUM H to Transformer. White wire from HUM N to transformer. Green to ground. From transformer, 1 wire to humidistat and 1 to humidifier. 1 wire between humidistat and humidifier.
Old 01-27-09, 02:56 PM
Jay11J's Avatar
should be wired like this.
Ignore the HUM and C, that end wires to your transformer.
HTML code is On
