Installing a Whole-House Powered Humidifier without a Sail Switch
Old 11-29-09, 07:57 PM
E
Hi All,
I recently installed a whole-house powered humidifier, and decided not to use the "sail switch" that came in the installation kit. My furnace had 120VAC hookups, so I put together a little blog post about how to use them to install the furnace without having to use a sail switch, and save some money too. Here it is, I hope you find it useful:
Humidifier Installation
Thanks,
Tom
Old 11-30-09, 06:38 AM
Jay11J's Avatar
Good post.
A couple of things came to mind.
Do you have A/C? If so, isn't the humidifier air flow being blocked by the A-Coil?
I would change that out let to a single outlet rather than the double.
Here is what I do.
The reason I suggest the single out let is a person can't plug something else into it. If say the furnace is running, and power is at that double out let, and someone wants to plug a shop vac in.. Plugging that into that outlet ti going to overdraw on the furnace board and may damage it and/or blow a fuse on the board. The AMP draw on most board are only allowed up to 3amps. Shop vac pulls a lot more.
Old 11-30-09, 07:46 AM
E
Thanks. Yes, I do have A/C, but no, it isn't blocked by the coil. For some reason, my coil is in the section above the section immediately above the furnace. Here's where I mounted the humidifier:
And here's the coil:
The furnace is only about a year or two old, and I think the original furnace was probably much taller (I've only owned the house for a few months, so I don't know for sure).
That's a good idea about putting in a single outlet. I hadn't thought of the possibility of damaging the board.
Thanks,
Tom
