Wiring Humidifier w/o HUM
Old 12-03-09, 09:56 PM
E
I want to install a Generalaire SL-16 onto my furnace (ICECO 90RS10EGS01) but my furnace doesn't have a 24VDC HUM hookup.
Should I ...
A) wire the 120VAC EAC terminals to a plug/switch for a 24VDC adapter that powers the humidifier/humidistat
or ...
B) wire the humidifier/humidstat directly to the 24VDC C & G(orW) terminals. If so how do I know the furnace will put out enough juice for the humidifier? Can I damage anything if it can't handle the load?
Thanks
EdgeAle
Old 12-03-09, 11:02 PM
Jay11J's Avatar
or ...
I would do A.
If you find that A is more work than you want to do, you can start off with B, and go from there.
Most of the time, it's not an issue, but some furnace acts up when you steal power from W.
HTML code is On
