Honeywell HE260A1002 - Water running 24/7
Received 0 Votes
This is the 2nd season with this problem - Humidifier was installed in 1998 by professional heating & Cooling company
2007 replaced the solenoid (A2012-S118) & water panel (still never worked right - will kick on but water will continue to run 24 X 7 unless you go turn humidity control to off
AC guy says that was the wrong solenoid - just replaced solenoid again (32001639-002) and same thing is happening - will kick on - but water continues to run..... what other part would need to be replaced.
Sounds like it's not wired up right, or something else than the solenold valve.
Follow the wire back to the furnace, and see where it's tied to, or another type of control.
