solenoid valve staying open-honeywell he265a1007
Old 02-07-11, 10:25 AM
Just bought a foreclosure that is about 5 yrs old. The solenoid valve is staying open even when the furnace is off. I tried cleaning in a water/clr solution with no luck. Is the valve stuck open, or maybe a problem w/ wiring or maybe humidistat? We are on city water so we are just running $$$ down the drain, literally. Any suggestions?
Old 02-07-11, 11:14 AM
I don't know much about humidifiers but there should be a shutoff valve for the water supply to it until you can get it fixed.
Old 02-07-11, 01:52 PM
hvactechfw's Avatar
Received 2 Votes on 2 Posts
remove the wiring from the solenoid valve and if the water still flows then it is time for a new solenoid valve. if this shuts it off then you may have a bad relay or another problem.
Smilies are Off
HTML code is On
