Position of Bypass Duct on Aprilaire 600A
Old 03-09-11, 10:01 AM
D
This will be my first DIY install of a humidifier. I have a Bryant 340AA furnace that I'll be attaching the Aprilaire (Return duct side) to. Is there a optimum position for the bypass duct mount relevant to the humidifier unit? What I mean is, should it sit higher, lower, or at the same height as the unit? Thanks in advance!
Old 03-09-11, 03:27 PM
hvactechfw's Avatar
Received 2 Votes on 2 Posts
does not matter could be any which way as long as you are getting correct airflow
Old 03-15-11, 11:55 AM
hvactechfw's Avatar
Old 03-16-11, 07:39 AM
D
Thanks! I truly appreciate this! Now it's time to get to work.
Old 03-21-11, 06:54 AM
D
Hi again. So I've wired up everything except the G (humidistat) to the G (thermostat). I am unsure where this is located in the furnace circuit board. Or am I supposed to take out the current wire on the the G (furnace) terminal and jump it with the G (humidistat)? I'm assuming that the current wire on that G terminal is for the thermostat. Thanks!
Old 03-21-11, 09:18 AM
Jay11J's Avatar
Yes, the G wire on the furnace now is from the t-stat. Wire that to the humidistat, and Gf from the humidstat now lands on G at the furnace.
Old 03-22-11, 12:04 PM
D
Great! Everything wired up and running well. Thanks again!
HTML code is On
