Add humidifier to XV95 and Honeywell HZ322
I currently have a Trane XV95 furnace with a honeywell HZ322 controller and I wanted to add a humidifier to the system. Any recommendations? Can I wire it through the HZ322? Any advice is greatly appreciated. Justin
There is no hook up on the zone board for the humidifier. There may be a couple of wire we may be hooking up to the zone control.
Depends on what model of humidifier you are going to use, we'll help you get it wired up right when you are ready to install the unit.
