Goodman furnace and NEST thermostat, need help wiring skuttle humidifier.
Received 0 Votes
Does this schematic apply to a Goodman Furnace - Model# GMNT080-4 with Skuttle Humidifier - Model 2001?
The Skuttle humidistat is mounted next to my thermostat in the hallway and has two wires, so I have the same dilemma as the original poster.
Thanks
Thanks
Received 0 Votes
This is the circuit board for my furnace. (see link) The humidifier is controlled via the HUM terminal on the board. I only see W, G, and R terminals on the board and no C terminal. Can you recommend a terminal to splice the C wire into? Or should this be grounded to the metal furnace housing?
I'm sure these are rookie questions, but I'm much more familiar with DC current, working on cars, etc. I appreciate the help and quick responses. You guys are an excellent resource.
http://nativesupplycompany.com/image...13-800x800.jpg
