Can I use a Aprilaire humidistat on my Honeywell humdifier?
Old 11-28-12, 07:53 AM
T
I just bought a house that has a Honeywell HE225 humidifier with their manual humidistat mounted on the furnace in an awkward place in the basement. Needless to say, that is inconvenient.
My old house has a Aprilaire humidifier with their #56 automatic humidistat. That has worked great for 10 years.
Can I use a the #56 on my HE225? I don't see why not, but I don't really know anything; so I need to ask.
Could I just swap the two, or would I be better off buy a new #56 for $70?
Or, is there another humidistat that you might recommend that is not overly expensive?
Thanks much.
Old 11-28-12, 09:07 PM
Jay11J's Avatar
yes, you may use the Aprilaire to run the Honeywell Humidifier.
Where would you put the new humidistat?
Old 11-28-12, 09:18 PM
T
I would put it on the return duct, right where the old one is. It is inconvenient, but since it is automatic I won't ever have to get to it.
I am a bit concerned about where to put the outdoor temperature sensor, but I can work that out.
Old 11-28-12, 09:52 PM
Jay11J's Avatar
Ok, I was hoping you were not planning on putting it in the hallway.
You can get to the unit itself to change pad every year tho?
Old 11-30-12, 09:13 AM
T
I can get to it easily enough; it is just more of hike than I care to make constantly when automatic ones are available.
Aprilaire says a dealer can install it for me, but did not address the question of whether I could install it. Hopefully it is just a matter of transferring from the old humidistat two existing wires from the solenoid, two existing wires from the furnace and attaching two new wires from the temperature sensor.
Old 11-30-12, 09:27 AM
Jay11J's Avatar
You will need more than just two wires with this.. You'll need 2 wires for power for it, 2 for outdoor sensor.
Old 11-30-12, 09:48 AM
T
6 wires.
4 existing wires from the old humidistat; two to the solenoid and two to the furnace.
2 new wires for the outdoor sensor.
No?
Old 11-30-12, 03:06 PM
Jay11J's Avatar
Yep, 6 wires is needed.
What's the make/model of the furnace, and we'll help yo uwire it up.
Old 11-30-12, 08:00 PM
T
I appreciate that!
Trane XR90 Furnace
Honeywell H8908B Humidistat
All installed 2006
I planned on using an Aprilaire #56, but just found
a Skuttle for $25 less. Is that a reputable brand?
If not, I will go with the Aprilaire.
Old 11-30-12, 09:07 PM
Jay11J's Avatar
What model of Skuttle did you come across?
Old 12-01-12, 06:59 AM
T
Skuttle Automatic Humidistat SEH-7100-000
Like I say, I don't want to save a little money and buy junk...
I had the Aprilaire at my old house for 12 years and it has worked fine.
My first idea was to swap humidistats from the two houses, but that seemed like a lot of work to get a 12 year old device and save $65.
Old 12-01-12, 05:46 PM
Jay11J's Avatar
I'd say that is a good product, and they been around too.. Looked at the reviews, and it had good review.
It's up to you what you want.
