TrueEase HE250 to Prestige EIM Wiring
Old 01-05-13, 06:54 PM
I'm Updating my thermostat to a Prestige 2.0 with EIM and adding a Honeywell TrueEase HE250 Bypass humidifier.
I have installed Thermostat (2 wire)and EIM and Heat and AC both work. I have wired the Humidifier to the transformer that came with it. The transformer is attached to a conduit box and has constant power. the wires from transformer to Humidifier have 24v. According to the wiring instructions that came with Humidifier and Prestige the only other wires i needed to hook up are the HUM on the Humidifier to U1 on EIM. I have done this and when I power on the humidifier it runs through what i would call a function check. (Baffle turns 180 degrees and the lights light up. But when the thermostat calls for humidity nothing happens at the humidifier. DIP switches on Humidifier are both ON (top one left, Bottom Right
[ATTACH=CONFIG]7524[/ATTACH]
Yellow and Red go to transformer. Blue and Green go to EIM terminals U1
[ATTACH=CONFIG]7525[/ATTACH]
This Is the EIM wiring I have from Top down:
Terminal Color Destination
R - Red -Thermostat
C - White - Thermostat
W - White - Furnace W
Y - Yellow - Furnace Y
Y - red - AC Unit
U1- Green - Humidifier HUM
U1 - blue - Humidifier HUM
RH, RC, R are jumpered
R - Red - Furnace R
C - White - AC unit
C- Blue - Furnace Com
S2 - White - Discharge temp sensor
S2 - Red - Discharge Temp sensor
S1 - Green - Return Temp sensor
S1 - Blue - Return Temp Sensor
I Dont know what else to Do someone please help!
Old 01-06-13, 04:14 PM
Nevermind!
I flipped the dip switches on the humidifier opposite of what the directions said (as stated above) and everything works perfect..
Old 01-06-13, 10:33 PM
Jay11J's Avatar
Let us know if you need anything else.
