Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Humidifiers and Dehumidifiers
Reload this Page >
HE360 humidifier, Whole house ventilation system> using Honneywell VisionPro IAQ
Old 01-07-13, 11:04 AM
A
Hi there,
I apologize if this question was asked before. I`m trying to upgrade my house thermostat and install a humidifier. I did purchase a Honneywell VisionPro IAQ thermostat and, I`m planning to connect my TrueFresh Ventilation System(VNT5150H 1000) and a Honneywell he360 whole house humidifier. I opted to buy a VisionPro IAQ thermostat in order to control all the devices with a single unit.
My questions is: If I`m using the VisionPro IAQ,do I still need to connect the Pressure Switch that came with the humidifier ? Can I just connect just the two yellow wires of the humidifier to the thermostat`s EIM? VisionPro IAQ should know when the furnace is running or not...
Thank you.
Old 01-08-13, 08:11 AM
Jay11J's Avatar
Just plug the 360 into the outlet, wire the two yellow wire to the HUM on the EIM.
And then you just set the set up menu letting it know you ahve it hooked up, and turn o w/ the heat calls.
When you get it, let me know and I"d be happy to help you with the set up menu.
Old 01-09-13, 12:55 PM
A
Thanks for the fast reply.
Ok, sounds easy. I will install it hopefully this coming weekend. The humidifier came with a Pressure Switch (https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2517EF.pdf) see page 5 ; but guess I don`t need to install it, since I`m using VisionPro IAQ. Right ?
Old 01-09-13, 05:08 PM
Jay11J's Avatar
Nope, the pressure kit insn't needed.
Old 01-15-13, 09:44 PM
A
Another pre install question
My furnace is a Tempstar 9N9MP1 (90+ Single stage,Cat IV,Gas furnace)
I`m looking at the installation manual for VisionPro IAQ and,it seems that for this furnace I need to follow Figure10(Typical hookup of conventional single-stage heat and cool system with single transformer (1H/1C conventional).).
I`m looking at the schematic and I`m confused...on the EIM board,do I have to connect together the (C) connector with (O/B),(Y) and (G)?
Thank you
Old 01-16-13, 05:59 AM
Jay11J's Avatar
No, you don't wire W,Y, G to C. You wire it to W, Y, G to those letters on your furnace.
Old 01-21-13, 10:02 PM
A
I just finished installing the thermostat. Everything went smooth. Thank you for the help.
Old 01-22-13, 06:52 AM
Jay11J's Avatar
Glad to help, and thanks for the update.
While you got the book out for the t-stat, I'd suggest you make sure set a couple of things.
-Set heating cycle to 3, and humidifier to come on only call of heat.
Old 01-22-13, 07:40 AM
A
OK, I will set it up when I get home.
220 - 3
240 -3
374 - 0 (heat or fan) ?
374 -2 (heat only)
For humidifier option, I was thinking to leave 374 - 2. It`s really dry in house in winter time.
I`ve set up the humidity to 35 %. I see if I go higher than that, the windows are starting to create water condensation around the edges.
For 400-404 I see that 404 fails all the time, regardless what percentage I set-up for ventilation. What I have now is:
400-2
401-3
402-19
403-155
404-30,40,60 % (regardless it keeps on failing ) - when P or F is being displayed, is it just a calculation of data points from 400 to 403, or an actual measurement of the air quality ?
My house size is 1950 sqft + basement 900 sqft (unfinished).
The Ventilation system is being measured at 153 cfm (as per sticker from the installer)
Old 01-22-13, 12:38 PM
Jay11J's Avatar
I have 374 on mine set to heat only, and at 40%, frost at 5. Do you have an outdoor sensor on yours?
I am not sure what's up with the Fail on fresh air.. Mine shows fail too no matter what I do.. I wonder if it's an software issue.
so, I just set mine on sq ft of the home, one bedroom, and cfm. The damper is opening as needed.
HTML code is On
