Aprilaire 700M not working
Old 01-15-13, 06:36 PM
D
I installed this 700M humidifier 4 years ago and I just noticed that its not working this season. After doing some research it seems that the solenoid valves going bad is common, so I ordered a new one. I installed it and still no water. I then went a little further and checked that I was getting 24v coming from the board on the furnace and the voltmeter read just under 24v. My humidistat clicks when I turn the dial so I dont think it is that. Either the new solenoid valve is bad or something else is wrong that I'm not seeing. Any help would be appreciated. Thanks
Old 01-15-13, 07:19 PM
Jay11J's Avatar
Is fan fan running on it?
Are you getting 24v at the solenoid?
Old 01-17-13, 03:11 PM
D
The fan that blows across the water panel does not seem to be running. Yes, I am getting 24v to the solenoid.
Old 01-17-13, 06:02 PM
Jay11J's Avatar
So you are getting water over the pad, just not a working fan?
Old 01-17-13, 07:07 PM
D
No water is getting past the solenoid. I have 24v going to the solenoid but it will not open to let the water pass through. I purchased a new solenoid but I am have the same problem with the new one. I think that the new valve is bad. I should be able to take the wire that provides the 24v to the valve and touch them to the solenoid wires and I should be able to hear the valve open and close. Isn't that correct? I just think I received a bad "new" valve. Don't you think so?
Old 01-18-13, 03:18 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
are you sure you have water to the solenoid? Crack open the inlet side and make sure.
Old 01-18-13, 08:55 PM
D
Yes, water supply is good.
Old 01-19-13, 05:00 AM
Jay11J's Avatar
Yeah, you should be hearing the valve click open/close.
