Hooking up Humidifier
I am about to install this exact setup on a Ducane MPGA100B4 gas furnace (with Honeywell ST9120C control board https://customer.honeywell.com/resou...0s/69-0781.pdf), two questions:
1) The red/white wires you have coming out of the humidifier in the schematic that are connecting to the relay, are they the 120v power wires (wired in series with a 120v power source) or the control wires that would otherwise go to the humidstat?
2) If they are the control wires, the pressure switch is not needed, correct? I would configure the Nest to use HUM + HEAT for the fan, correct?
Thanks for all your help!
