Aprilaire 600 Not working
I had an Aprilaire 600 professionally installed and it has always worked fine until the last two winters. It was installed about 6-8 years ago. It will not even work in the Test/Reset Mode. How should I troubleshoot? Should I disconnect the two power wires to test for 24v to see if it is receiving power? Could the transformer go out? The heater works fine and a/c works fine. Recently had the blower motor replaced this year. I am new to working with a voltage meter and all the troubleshooting steps would be helpful.
Thanks but no
The blower motor was replaced after it stopped working. I guess I will check the voltage and best guess it from there. If someone else has suggestions, glad to hear them.
